Wiper fault on 71 Sprint
The wipers on my 71 Sprint only work on the slow speed and wont 'park'. Any advice always appreciated before I contort myself under the dashboard.
Regards, Andrew
Regards, Andrew
- andrewdmoore
I had wipers that would work on normal & fast speeds, but wouldn't park. It turned out to be a wire broken inside the insulation just back from a Lucar connector, where it connected to the switch! - I think it was just about accessible through the ashtray hole.
It was like that for so long that I sometimes still switch them off when the wipers are at the bottom....
Matthew
Matthew
- ppnelan
Andrew,
Were the wipers working, then stopped? If so, it may well be the park switch, which is part of the wiper motor. These are cheap and easy to replace.
I had similar problems on my +2, but it was down to previous owner "modifications": no park switch; wrong type of switch on the dash, and incorrect wiring.
The first thing to do is to figure how it is supposed to work, then get out the volt meter!
The wiring should be very similar to this:
http://www.mgb-stuff.org.uk/s_wiper.htm
(look at "early two-speed")
good luck and best regards, iain
- iain.hamlton
As for operating at a single speed. The fast speed often won't seem any quicker than slow - until you are using them in anger and driving in the rain. At least that's my experience (and it gets a mention in the workshop manual I seem to recall).
Elliott - 70 S4 dhc
ElliottN - Second Gear
