Starter motor replacement
I'm in just replacing the starter motor on my Elan +2 and would like to know what type of grease or lubricant I should apply to the pinion. From examining the split and fractured pinion on the one I've removed (made a noise like very healthy christmas cracker when it failed), it looks a bit dry.
Any suggestions?
Happy New Year.
Martin.
Any suggestions?
Happy New Year.
Martin.
- hemsley
Just an educated guess but maybe it should be dry to prevent crud sticking to it?
Not sure what is recommended but over the years I have worked a small amount of oil into the pinion and then wiped most of it off ........ so that it is lubricated but only just
Grease will create a sticky mess and as JPC says too much lubricant will cause dust to adhere and cause more problems than it solves.
I have found that when very lightly lubricated they tend to stick less and are a little bit quieter in operation
Maybe just a little something on the teeth to help them engage?
I have had success with a little atf on the shaft once a year --and make sure the bung is in place --ed
Hi Martin
I may be wrong on this but I was given to understand that the correct lubricant is powdered graphite- the same stuff that should be used for door locks.
Don't know where you buy it however because my old man gave me the stuff 20 odd years ago.
- worzel
You should only use a dry lubricant, powdered graphite is the recommended lubricant, you don't want oil or grease on the pinion that will collect dust or dirt in it. I haven't used it for this purpose but I know you can buy a spray can which is a dry graphite lubricant at Canadian tyre stores here in Canada.
Keith Marshall
- saildrive2001
