All I get is a click on the starter.
• Page 3 of 3 • 1, 2, 3
All grounds are ok. I will try and remember to get you the engine number and I need to send the paint code from the VIN plate to Andy.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham (Bought new), 05 Elise RD (Bought new),
99 Elise190, 05 Elise BLK (Bought nearly new), 2024 Emira, 2005 MiataSpeed Turbo
tvacc - Fourth Gear
HI all,
We are all set. I made the jumper, reinstalled the starter and all if fine.
Thanks to all for the help. It has been many years since I worked on an Elan and my age is showing. I just dont remember it all....all the time. But you all pointed me in the right direction. Thanks.
Tony V
Tony V
Tony Vaccaro
tvacc - Fourth Gear
One issue with using a direct trigger connection to a pre-engage starter from the ignition swith is that the solenoid for many pre-engage starters draws a much heavier current than the original solenoid and this can lead to the ignition switch contacts over heating and buring out.
I use a small conventional 30 amp relay to take the load off the ignition swtich to the solenoid on my pre-engage starter
It never ceases to amaze me what a great group of people Lotus folk are. You all are great! Thanks again.
Tony V
Tony V
Tony Vaccaro
tvacc - Fourth Gear
This will be a relief to anyone concerned about there ignition switch.
https://www.youtube.com/watch?v=MOENEG2KajY
- Craven
I had this exact problem a few weeks ago, and I have the normal inertia lucas starter. i was at a show and had to start the car to reverse into a parking spot. Click, Click, Click! Embarrassedly, the car had to be pushed into the bay. I then tried again, engine turned and it started, as it has every time since.
Baffled!
Baffled!
- davidj
Hi Davidj,
I suggest you look at condition of Bendix and fit new one. Also check for wear in the Oillite Bush and fit a new one very cheap and easy to change.
- alan.barker
