Is there a black-restore product for rocker switches?
PostPost by: timdaw » Thu Jul 14, 2022 10:11 am
I tried the baby oil approach as I also don't like using anything with silicon in it. I also wanted a 'not too black' look, since the dash has not been refinished and I prefer a bit of patina.
I cleaned the switches with acetone on a cotton bud and then applied baby oil. Wiped off the residue and did a second coat. I was very pleased with the result...
Before:
IMG_9507.jpeg and
After:
IMG_9511.jpeg and
If you prefer the switches to be very black, then I can recommend the Wurth plastic dye product. Actually it's also available in anthracite. It lasts for ages, unlike most other products.
timdaw
New-tral
PostPost by: woodie » Thu Jul 14, 2022 11:28 am
I went down a different path, and made bronze covers (very thin). Polished sides satin fronts then chrome plated..
20211111_185711.jpg and
woodie
First Gear
First Gear
PostPost by: smo17003 » Thu Jul 14, 2022 12:47 pm
I've done mine with Satin Black aerosol paint. After cleaning a coat of U-Pol Plast X plastic adhesion promoter, a coat of primer and two coats of paint.
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: skyarch » Thu Jul 14, 2022 4:35 pm
I've been using this with good results
skyarch
First Gear
First Gear
PostPost by: JohnMorin » Tue Jul 26, 2022 5:58 pm
I've just done this prior to fitting my new dash. I used fine wire wool and WD40, works a treat.
1969 Elan S4 FHC, purchased in 1978, now with a big valve engine.
JohnMorin
Previous
