Voltage regulator(?)
PostPost by: yandy » Fri Feb 06, 2009 12:30 pm
Beware...
If you need a new voltage stabiliser you can buy one on Ebay http://cgi.ebay.co.uk/SOLID-STATE-VOLTA ... =72%3A1689
It is an easy replacement for the original type.
Further investigation reveals that this is the very item that 'goosed' itself so quickly. Of course that doesn't rule out the problem being with my car, and that will be tested with John's version, very nicely packaged into an original casing, and costing only pennies more.
Just, beware.
Exceedingly yellow '68 +2
Todays top tip: create a spooky lighting effect by forgetting to switch off and remove your torch from the nose area before refitting the grille.
yandy
First Gear
First Gear
PostPost by: neilsjuke » Fri Feb 06, 2009 1:08 pm
The wires to the voltage stabilizer should be green only plus the earth (black) to the case the supply to B and I to gauges . Reds are side lighting and Red /l green wiper you need to check workshop manuel as this is from my memory when I worked in the 70s for Lucas .
Neil
neilsjuke
Previous
Users browsing this forum: No registered users and 62 guests
