+2 brake warning light
PostPost by: checkrail » Fri Jul 07, 2023 4:00 pm
Hi all, S130 with ashtray in the dash.
I turned my battery master switch on and the brake fail warning light illuminated, but I don't have a low level device on the master cylinder!
Turning the ignition on the light went out ,started the engine and everything including the tach is fine all electrics are working o.k. I pulled the warning light out from the dash, and the two connections are really tight.
This has got me really baffled I 've had the +2 four years and this is the first time it's happened.
Any advice please? Thank you John
checkrail
PostPost by: h20hamelan » Fri Jul 07, 2023 4:30 pm
How are the wires behind instrument panel, check contacts in bulb housing?
Love your Mother
Earth
PostPost by: checkrail » Fri Jul 07, 2023 6:53 pm
the two wires are as the workshop manual: one red/white one blue/white, in 1st class condition
checkrail
PostPost by: steve.thomas » Sat Jul 08, 2023 8:16 am
On my S130 the brake warning light is a combined fluid level and handbrake warning light. Mine has the fuses in the dash, so maybe the spec changed on later cars.
steve.thomas
PostPost by: checkrail » Sat Jul 08, 2023 11:59 am
Mine has all fuse boxes in the engine bay and seperate handbrake warning device
checkrail
Users browsing this forum: No registered users and 43 guests
