Electronic speedo sensor
There are a few posts on here about conversion to GPS-based and hall-effect based speedometer setups (using propshaft bolts as 'teeth'.)
However I didn't manage to find any information about fitting an encoder directly to the Speedo cable take-off (where the angle drive normally attaches.) This could be quite a clean way to do it, if a suitable sensor exists. Perhaps something like this?
I don't have my car to hand but remember there isn't much space. Has anyone done something similar?
At the speedo end, I'm hoping to keep it looking original but saw there are people who can replace the Smiths innards with an electronic conversion. Does anyone know roughly how much this typically costs? (In UK.)
Thanks for any pointers.
- ill_will
Will,
Last time I looked, the smiths speedo has a digital electronic green odometer display. If I remember correctly one of our contributors in California has used a separate drive for his speedometer this consists of a small electric motor that is controlled by a GPS signal. This system allows you to fit the GPS receiver and the drive motor elsewhere in the car, with a speedo cable from the motor to the original speedometer. Hopefully the man from California will be able to give more complete advice.
Richard Hawkins
Richard Hawkins
- RichardHawkins
The Smith electronic unit is similar to the original, but not more. For me it was a bargain and reasonable compared to the cost of removing the Lotus 5 speed box and fixing the stripped speedo gears.
It works very well and if you are not put off by the looks, I can recommend it.
Philipp
Philipp
- phil1800
Thanks for the feedback. I have the early style gauges like on the left in you picture, Philipp.
It looks like converting the 'innards' of an existing speedo and retaining the dial and rotors isn't an option, which is a bit of a shame. I will look into the GPS option though.
Geni - thanks for the offer. I'll contact you separately.
- ill_will
Richard Hawkins referes to a unit that drives the original, non modified, speedometer. I have one, along
with 1owner69..., the fellow from California.
https://speedhut.com/categories/speedbox.html
A simpler, cleaner method, I think.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
