Festoon 239
I've got an interior dash light from RDent.com. It lists festoon 239 as the bulb type. The bulbs get too hot. The original lamp had a melted lens. Anyone know of the LED equivalent bulb? I get lots of hits via the web....many look usable... but i'd rather hear from someone who has bought and can confirm
Thanks very much
Gentry
Thanks very much
Gentry
GD
67 s3 dhc
67 s3 dhc
gentry74 - Second Gear
I bought a festoon bulb off the internet that looked ok but didn't fit. Ended up getting the one from RD and it works fine. Maybe you have a wiring problem.
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
I’ve replaced all the festoons with LED versions for the same reason - the covers showed signs of heat damage. Unfortunately it was a few years ago so I can’t remember the code numbers but I think I just measured the originals and bought as close as I could get. Many of them are available in different colour temperatures and you should buy the 3000 kelvin (= ‘warm white’) versions if you want the same look / feel as the originals.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
I fitted this one, a bit brighter than the original but I like it!
Replaced indicators, brake and side lights at the same time and pleased with results.
Makes all the exterior lights more visible as well
https://www.classiccarleds.co.uk/produc ... 39-254-c5w
Lotus Elan Sprint FHC 1973
RichardS - Third Gear
thanks all. This is helpful. I will search for equivalent via US reseller. To be clear: I already have the correct festoon 239 regular bulb. I just dont want to have the lens melt if I accidentally leave the map light on for more than 10 minutes.... so want LED instead (since its an option)
GD
67 s3 dhc
67 s3 dhc
Hi Gentry,
Festoon lamps come in different lengths. It helps to specify the length as well as the type number.
Eric in Burnley
1967 S3 DHC
Eric in Burnley
1967 S3 DHC
- ericbushby
