RD Ent alternator
PostPost by: AlanJH » Sun Oct 16, 2022 4:58 pm
Does anyone know the model number or a car source I can use to have the alternator tested? I have a charging issue and tried to have the alternator tested at and tried the 89 Chevy Sprint which looked like the correct connection but the tester couldn’t get response.
Alan Hill
1967 Elan S3 SS
Delaware
AlanJH
First Gear
First Gear
PostPost by: pharriso » Sun Oct 16, 2022 5:12 pm
Follow the link for applications - https://www.amazon.com/Premier-Gear-PG-14684-Professional-Alternator/dp/B00KL51IM8
It lists vehicles: PREMIER GEAR PG-14684 Alternator Replacement for Sidekick L4 (89-89), Samurai L4 (85-95), Sj413 L4 (85-85), Forsa L3 (87-88), Firefly L3 (87-88), Metro L3 (89-93), Sprint L3 (87-88), grey
& Part numbers: ‎100211-1410, 100211-1411, 100211-1550, 100211-1551, 100211-2200, 100211-2201, 100211-4070, 100211-4071, 100211-6270, 31400-82110, 31400-82111, 31400-82611, 31400-83010, 31400-86010, 96055601, 96056922, 96068024 14684, 14684N, 14870, 20170210, 210-0637, 213-8329, 213-8331, 213-8900, 213-8901, 334-1098, 334-1747, 36-14684, 400-52015, 400-52015R, 437163, 58449, 8EL 726 333-001, 94623, AL-240
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: AlanJH » Sun Oct 16, 2022 5:57 pm
You are the man! I was able to have the alternator tested and it’s dead. Ordered a new one using the link supplied. Thank you.
Alan Hill
1967 Elan S3 SS
Delaware
AlanJH
First Gear
First Gear
PostPost by: stugilmour » Fri Oct 21, 2022 1:22 am
Alan, when you receive your alternator can you confirm you get one with the correct pulley installed? I was away from the car for a few days so just saw this thread. I had to recently purchase a replacement alternator and the one I got had a pulley for a wider belt. I am trying to order a second replacement with the correct pulley size, or at a minimum have a pulley available.
Thanks in advance
Stu
Stu
1969 Plus 2 Federal LHD
PostPost by: joe7 » Fri Oct 21, 2022 2:52 pm
I bought my alternator from RD. The pulley didn't line up with the crank pulley. Rather than go the spacer route I did the following: Bolt generator to its bracket, bolt alt to its bracket, bolt the two together. Brought it to my favorite auto electric guys to line up. They installed a new pulley that lined up perfectly with the generator pulley and had the correct width to match the generator pulley width. $40.00, what a deal!
joe7
PostPost by: AlanJH » Sat Oct 22, 2022 12:25 pm
Stu,
The new alternator came with a pulley installed for the v belt. The pulley has slight dimensional differences, mm here, mm there, but the existing fan belt seems to actually fit the sides of the v pulley better.
Hope this helps.
Alan Hill
1967 Elan S3 SS
Delaware
AlanJH
First Gear
First Gear
PostPost by: stugilmour » Sun Oct 30, 2022 6:19 pm
Thanks for the reply. Sorry for late reply. That clarifies things a bunch.
I opted to use my original pulley (that came with the original alternator kit) on the replacement alternator. Worked out but was a pain when on the road. In order to remove and replace the pulley we needed to source an impact driver during a holiday long weekend, which ended up delayed when a helpful friend with the correct tool tested positive. :( Ended up OK but a couple of days delay on my big trip of the year.
My plan is to purchase a spare pulley and alternator and have it available. Not sure if it is exclusively a Plus 2 Federal issue, but there is very little clearance to my steering shaft, and I had a heck of a time finding a belt and pulley combo that would fit.
Thanks again. Will have to follow up as have not heard from my supplier in in a while.
Stu
Stu
