Elan S4/Sprint Window Switch Crossover Wiring
Making preparations for fitting a new dash loom.
Some of the wiring I discovered was quite tragic, but one thing I noticed on the new loom is that there is no provision for the window switch crossover wires. Previously this was achieved using spade piggyback connectors and was just a mess on both switches.
I have a sacrificial window switch so toyed with the idea of soldering crossover wires onto the spade connectors below where the power and earth female spades fit. I drilled 2mm holes and fitted the jumpers which I will solder in place.
Thought I would share this before going ahead in case there’s anything I missed. Couldn’t find anything on this subject doing a forum search.
71 Elan Sprint FHC Pistachio
36/0262E
36/0262E
- Bodmin
I had understood the switches came with the crossover wiring in place, very similar to how you are proposing to modify yours. Mine do.
Have a look at:
https://lotuselan.net/forums/viewtopic.php?f=38&t=34706&start=
Which has a picture of a R Dent switch with crossover wiring in place.
Hence no crossover wiring in the loom.
Andy.
Have a look at:
Andy.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Andy8421 wrote:I had understood the switches came with the crossover wiring in place, very similar to how you are proposing to modify yours. Mine do.
Have a look at:
Andy.
Good to know I’m not barking up the wrong tree.
Mind you I’m not keen on uninsulated cross over wires, although I suppose if they’re rigid enough the risk of a short is small.
Mind you I’m not keen on uninstalling
36/0262E
36/0262E
- Bodmin
