washer pump and more snags
PostPost by: grand_manitou » Sun Jun 12, 2022 2:42 am
Greetings,
I recently acquired a lotus elan coupe 1966 and there is a few minor snags...
-No washer pump, bottle or knob. Any suggestion as to where I could get those parts? Also, how can I access the section where the nozzle are, to pass the tubes?
-There's a switch that does nothing and could be the ventilation. These car has 1 speed fan?
-The heater may be missing as well.
-I'm I supposed to have a parking brake?
-And, another thing, one of the window does not want to go up...
-There's a big gap between the body and the chrome window trim. Is it supposed to be like this or I'm missing some weather stripping?
Anyway, where can I find electric diagrams for this model? Any maintenance manual that I should buy?
thanks a lot!
grand_manitou
First Gear
First Gear
PostPost by: jcocking » Sun Jun 12, 2022 11:17 am
There are several wiring diagrams in the wiki.
https://lotuselan.net/wiki/Category:Electrical
And welcome to Elan ownership.
Jeff Cocking
jcocking
PostPost by: gjz30075 » Sun Jun 12, 2022 7:45 pm
Welcome to the forum. It's best to break out your issues one at a time and present them in
the various sub topic areas. To answer a few:
Yes, your car came with a parking brake.
One speed fan controlled by a simple on/off toggle switch. Mine didn't do anything at first
either until I wiggled it. I eventually replaced the switch. Not easy as the dash needs to be
pulled back.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: grand_manitou » Mon Jun 13, 2022 1:58 am
Alright, there's a parking brake.... where is it?
On mine, its probably gone, but where is it supposed to be?
grand_manitou
First Gear
First Gear
PostPost by: snowyelan » Mon Jun 13, 2022 3:44 am
There's a fair number of us Canucks on the forum. If you are comfortable sharing where you are in Canada you will likely find someone local that can meet up and help you out.
Rdent.com has parts manuals online. They will give you a general idea of what goes where.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
PostPost by: steve lyle » Mon Jun 13, 2022 12:37 pm
Parking brake handle is under the dash. Look for an umbrella handle sort of thing. Pull out to engage, twist and push in to disengage.
Steve Lyle
2007 BMW 335i Coupe
steve lyle
