interior light wiring in elan s1 rear loom?
PostPost by: Andrew » Thu Feb 10, 2022 12:52 pm
My first post on the forum having recently acquired an S1 Elan from David Rose.
Amongst a range of jobs I'm in the process of replacing the wiring loom. The replacement rear loom, produced by Autosparks, has additional purple and purple/white wires which are not present on the original rear loom.
It looks like it is to accommodate two additional interior lights which to my knowledge weren't fitted to a s1 or 2. Certainly the wiring diagrams I have don't show more than the single interior light on the dash.
Before I cut into the new loom to remove the surplus wires can I check whether any of you have come across this before please and/or can explain what the additional wiring is for?
many thanks
Andrew
Andrew
New-tral
PostPost by: 661 » Thu Feb 10, 2022 12:56 pm
Hi Andrew,
Good luck with your project.
Do you have the workshop manual with copies of the wiring diagrams?
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: Andrew » Thu Feb 10, 2022 2:43 pm
Hi Graeme,
yes I have the workshop manual and wiring diagrams.
Having now heard back from the supplier, it transpires that despite the rear loom being listed as an S1/S2 loom it also incorporates the wires for the two interior lights of the S3 coupe.
So at least mystery solved :)
Andrew
Andrew
New-tral
PostPost by: Bill » Thu Feb 10, 2022 7:50 pm
Andrew
I have both an S1 (23/0538, owned and driven for 58 years)) and a Sprint coupe.
The Si has NO CABIN LIGHTS other than the dash mounted one so the extra wires are redundant. Judging by the wire colours they are for the later series coupe rear cabin side mounted lights.
I have rewired both.
Bill
Bill Rathlef
Vancouver Island, Canada
Bill
PostPost by: Andrew » Fri Feb 11, 2022 8:53 am
thanks Bill, that's most helpful. Yes the problem stems from the replacement loom incorporating the extra wires for later coupe interior side lights as you suggest.
Andrew
Andrew
New-tral
PostPost by: vstibbard » Fri Feb 11, 2022 10:36 am
They were added with introduction of S2 coupe. I had a pre airflow coupe and rest of loom was S1/2.
Vaughan
PostPost by: nomad » Fri Mar 11, 2022 8:14 am
Stock S1, in the states anyway, had an additional unused wire for a backup light.
Kurt
nomad
PostPost by: snowyelan » Fri Mar 11, 2022 1:06 pm
I'd personally just leave them. My S4 DHC has them and I considered removing them but figured if I ever wanted to add an electric fuel pump they would be useful.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
PostPost by: billwill » Sat Mar 12, 2022 12:15 am
I used the extra wires for a heated rear window for a long time.
