Lotus Elan
Does anyone recognise this part?
PostPost by: JonB » Sat Nov 09, 2024 6:10 pm
I’m overhauling my 4 speed gearbox. I found this detent plunger in the recess below the reverse idler gear. I don’t know where it came from. Not on the diagrams in the workshop manual as far as I can see. Can’t find a spring or hole for it to sit in.
IMG_4608.jpeg and
About 10 mm long…
Any ideas? It must go somewhere!
Thanks in advance
PostPost by: joe7 » Sat Nov 09, 2024 6:51 pm
That's a"plunger" which goes in the front of the trans through the hole in the side of the main case. There should be 2 and a small pin that goes into the center shift rail. Its purpose is to prevent engagement of 2 gears at once. On Rd website "Selector Shaft Interlocking Plunger Set"
joe7
PostPost by: ElanDNA » Sat Nov 09, 2024 7:16 pm
JonB wrote:Hi
Thanks in advance
This is how it all comes together....
P020615_11.53.JPG and
PostPost by: JonB » Sat Nov 09, 2024 8:14 pm
Where is it in the parts diagram?
https://rdent.com/manuals/index.html
PostPost by: ElanDNA » Sat Nov 09, 2024 8:24 pm
JonB wrote:Where is it in the parts diagram?
Number 29 twice, 30.
The housing plug is not shown.
Greetings Urs
Screenshot 2024-11-09 211847.jpg and
PostPost by: JonB » Sat Nov 09, 2024 8:31 pm
Now I’m worried. Only found one of them, but wil check the casing later.
Thanks!
PostPost by: JonB » Sat Nov 09, 2024 9:25 pm
Ok. Found the second one in situ- phew - and fitted the first one between the centre selector rod and reverse. But there is nothing under that cap in the casing (arrowed in the earlier picture) and I don’t see the thin bit that’s in the photo. It may be part 30, a pin. There is a hole in the centre rid for it so I am guessing it goes through there?
PostPost by: JonB » Sat Nov 09, 2024 9:35 pm
Panic over I found it. Item 10 in the dismantling procedure describes it. I forgot I’d bagged it up and labelled the bag “10”.
I am still wondering what goes directly under that cap though…
PostPost by: Blockhead » Sun Nov 10, 2024 12:32 pm
Here's a YouTube video that shows the installation of the plungers (13.10 min) without removing the plug:
https://www.youtube.com/watch?v=LJ7R5Q5Q7aA
Blockhead
New-tral
PostPost by: Elan45 » Mon Nov 11, 2024 5:57 am
what is the diameter and length? That will determine its position too.
Rpger
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: JonB » Mon Nov 11, 2024 9:27 am
Great video, Blockhead, thanks. A shame he didn't do a full dismantle. I learned that you can't evaluate the condition of the baulk rings without doing this, so when he says it's OK I think he is guessing.. unless he ran it beforehand? In my case I have not driven the car, so I can't be sure about the box condition.
@Elan45, no need. One of the plungers was still in situ, therefore the loose one I was asking about came from the other position (the gap between the reverse and the centre selector rod).
PostPost by: alanr » Mon Nov 11, 2024 9:28 pm
i would strongly suggest you always replace all baulk rings as a matter of routine every time a gearbox is stripped regardless of how good or not they look.They are not that expensive.
Just not worth the risk of putting it all back together and then finding you have a crunchy gearchange.
Currently:-
1971 +2 S130/ 5speed Type 9.
PostPost by: JonB » Tue Nov 12, 2024 10:32 am
I did say I was overhauling it, Alan. This means a clean out, seals, baulk rings, bearings, gaskets, bushes, even a new anti sizzle bush for the gearstick. Oh, and a nice coat of green paint to top it off. :D
Actually, I am nearly done with it. Waiting for parts.
PostPost by: SENC » Tue Nov 12, 2024 6:06 pm
Be sure to get the right baulk rings - early vs late are different.
Henry
69 Elan S4
65 Seven S2
PostPost by: RichardHawkins » Tue Nov 12, 2024 7:50 pm
John & Others,
Excuse me high jacking this topic, but you mentioned the anti sizzle bush. The manual mentions Loctite AV when reassembling the gear stick arrangement. What grade of Loctite are people using these days?
Richard Hawkins
RichardHawkins
