2000e reverse block
Whilst just assembling my gear lever turret into my rebuilt 2000e gearbox, I noticed the reverse gear block "pivot peg" is located into the hole in the turret casting and appears to be held in position with a "roll/ or "bissel pin" , which I do not have!
I've tried the normal suspects trying to acquire one, but no-one seems to know what I mean
( I can't believe we are down to that level of lack of knowledge already - shame! )
Comes to mind it's just a engineering roll pin so I could probably source one from flea bay or similar.
Question is, does anyone know the dimensions of the pin or otherwise, that I require? - (otherwise I suppose I'll have to get the HSS drills out and find the nearest sized one to fit, in the pin, hole?)
Phil.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
Phil
Not totally sure what you mean so can you take a photo and perhaps indicate where the pin is. If you find out the size of the roll pin, let me know as I have a box full of various sizes and will happily send you one if I have the correct dimensions
Tony
Tony
- tonyabacus
Users browsing this forum: Joncyclet and 4 guests
