remove gearbox
No you cannot. Engine has to be removed to allow gearbox to come out.
Eric in Burnley
Eric in Burnley
- ericbushby
Sorry to be the dissident here, but the box can be removed without the engine - I have done so more than once. It’s not easy, but it’s doable. Whether it’s the best way is subject to opinion
There have been numerous threads on this in the past.
- elancoupe
Mike,
That is the first I have heard of it. I thought I followed this forum closely, Thank you for the enlightenment. I have removed the engine and gearbox three times now although not for gearbox problems.
Eric
Eric
- ericbushby
I have read a description of gearbox removal without removing the engine, but given the apparent difficulty (separate bell housing to engine, remove clutch and flywheel, separate bell housing from gearbox, remove gearbox) I question how much time is saved. To me, having pulled engines a few engines out of Elans over the years, it's much easier/faster to pull engine/gearbox out together. Though these days, with a two post lift, I just remove the body when I need to get the engine out.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Here is a thread refered to by Mike (removing the g/box with engine in place)
viewtopic.php?f=14&t=16024&start=
I have never tried it and doubt I ever would
Thanks Brian,
I was just looking for that.
I have read and I think, understood Mike`s description.
My thoughts are that is too difficult and there are too many points that have to be done correctly without easy access. I already have to do things twice as it is, without adding difficulties to the process. Also, I do not have a lift so I would be working on the floor.
But, never say it can`t be done.
Eric
wolfchen, good luck if you go for it and let us know how you go on.
Eric
- ericbushby
bitsobrits wrote:I have read a description of gearbox removal without removing the engine, but given the apparent difficulty (separate bell housing to engine, remove clutch and flywheel, separate bell housing from gearbox, remove gearbox) I question how much time is saved. To me, having pulled engines a few engines out of Elans over the years, it's much easier/faster to pull engine/gearbox out together. Though these days, with a two post lift, I just remove the body when I need to get the engine out.
Just to be clear, clutch and flywheel removal is not needed.
I have found, that in my car’s current configuration, the TTR manifold makes this procedure much more difficult - I probably would not do it this way. This is because the manifold makes removing the bell bolts almost impossible without removing the manifold. Anyone who has taken these on and off will tell you that it is no picnic.
With more a more traditional manifold , I didn’t find it to be all that difficult, car on jack stands, just me and a couple floor jacks did it in a few hours.
Like so many things, to each his own.
- elancoupe
+1 engine out followrd by gearbox out.
For me to lift a gearbox back into place from below is far too heavy . A real gut buster or instant hernia lol
- alan.barker
