slave cylinder
Can anyone tell me where to get a genuine slave cylinder for the Elan. I am a bit unsure of the quality of ones sold by the usual outlets and eBay. I think it's Girling but not sure.
I lost fluid the other night. luckily I had some fluid in the boot and the car got me home.I have already changed the seals but its still leaking.The pipes and fittings to it are all sound but the bore of the cylinder is a bit tatty so a new one is sought
Comments if possible please
G
G
- MACCA.GLM
Escort Twin Cam / Mexico has the same cylinder. You'll probably have more hits searching under Escort Twin Cam/ RS1600/ Mexico than under Lotus Elan. Refer link below:
https://www.burtonpower.com/girling-clu ... 67950.html
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
I recently had an old Lockheed brake master cylinder rebuilt by Past Parts in Bury St Edmunds.
The bore was honed and a stainless steel liner inserted plus all new seals and the body refinished. Slightly more expensive than a new off the shelf "pattern part" from the Far East but will probably last for another 50 years.
Maybe worth giving them a call
https://www.pastparts.co.uk/services-products/
- TJS
2cams70 wrote:Escort Twin Cam / Mexico has the same cylinder. You'll probably have more hits searching under Escort Twin Cam/ RS1600/ Mexico than under Lotus Elan. Refer link below:
I bought this part in 2019, and can confirm it fits the Elan, having the correct 0.875" bore. In fact, it was identical to the cylinder I removed, with Girling lettering and part number.
draenog - Third Gear
Personally I’m not really a fan of stainless steel liners in cylinders unless you really have to. Inserting a liner decreases the wall thickness and strength of the cylinder it’s inserted into. For a master cylinder you may get away with it but the clutch slave cylinder even without a sleeve inserted is quite thin in the wall particularly at the circlip groove.
- 2cams70
512BB wrote:'I recently had an old Lockheed brake master cylinder rebuilt by Past Parts in Bury St Edmunds'
How much did they charge for that service?
Leslie
£80 (plus VAT) for the master cylinder and £75 each for rebuilt / replated brake callipers. Turnaround time 3 weeks, but quicker if the situation requires.
- TJS
