Rear hub nut size
This rear hub retaining nyloc was supplied to me a few years ago (I can’t remember which supplier) and is unused. When checking I found it is too high and not fully engaging the thread - the nyloc that came off was half height. What thread size is this so I can get a replacement please?
Thank you.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Malcom
The rear hub nuts are 5/8" UNF and were originally of the 'Thin' profile. As far as I can tell these generally are no longer available, only the full height nuts.
My original thin nuts were of about 0.550" high compared with the full height nut of 0.750" height.
If you have access to a lathe, the full height can be readily reduced to the thin height taking care to keep the thread perpendicular to the new face as picture.
I am happy to machine these for you if you cover postage cost.
Gary
Gary
Gary
1972 Elan +2 S130/5
2001 Elise S2
1972 Elan +2 S130/5
2001 Elise S2
- Gazzerb
Hi Malcolm
Spalding Fasteners have 5/8 UNF `half` Nyloc nuts in stock in quantities of five upwards. They are on ebay just now. Although these might be too thin and a slightly shortened full nut may be better.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Thank you both, Gary for your kind offer and Eric for the advice and info on Spalding Fastners. Before I ask Gary to machine some nylocs for me, what is the general opinion please about the safety of using half height nyloc rather than original 0.550” height in this situation - a genuine risk or just theoretical? Which would you use?
Thank you.
Malcolm
Thank you.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
'what is the general opinion please about the safety of using half height nyloc rather than original 0.550” height in this situation'
That would depend on what the half height measured. I certainly would not use anything thinner than the original height.
On many occasions, I have filed down nylocks to suite a particular application. Nothing difficult in that, just decent files required and a good eye.
Leslie
Leslie
- 512BB
Craven wrote:Watch out for the grade of nut, can’t recall torque but its high.
Thanks. The torque is 100-110 lb ft. What grade should I select, please?
Thanks, Leslie
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
I’ll check them out.
Thanks for all the advice.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
smo17003 wrote:Rear hub nuts and the thick washers are both available from Kelvedon, SJS, etc. I would expect that they are correct for size and grade if they value their reputation as suppliers.
Just to provide feedback and complete the thread for future reference:
Spyder and SJS supply the hub nyloc machined to the correct height, But Kelvedon supply a full height nyloc to be machined.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
