Transmission case Crack
Thanks.
Lou
Louis Lottner
Elan S2 1965 #26-4840
Colin Chapman’s immortal words ‘Simplify, then add lightness’
loueelotus - Second Gear
I doubt it is a crack
Rather from manufacturing
See if you can get a knife in the “crack”
Love your Mother
Earth
Love your Mother
Earth
- Location: RACECAR spelled backward, is——RACECAR! Kayak, Kayak. The Faster You Drive...The Slower You Age
Yes I can.. A thin razor on the tip when the tapered plug is tight.. I added an close up photo before marking it..
Louis Lottner
The easiest way is the way that solves it properly.
In my mind that is fitting a replacement casing. Once you've done that you can forget about whether the repair is going to withstand use or not.
promotor - Fourth Gear
Where can I get a case if need be?
Louis Lottner
FWIW Despite my pessimism my son in law had remarkable results with carefully applied JBweld on the cracked gearbox of his modern daily driver.
- Baggy2
It's cracked because the plug has been overtightened. Easiest way is JB Weld, which can last a longtime !. Proper way is a weld.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
JB Weld is a very good structural adhesive. Dont get the fast cure, but the original overnight curing one.
The trick will be the prep. The better you can clean all oils or greases, abrade the surface, then final clean with alcohol, the better your results will be.
Ian
Ian
- Ianashdown
Unless its no issue for you to get the trans out then go with the JB weld and follow the advice RE cleaning and prep. That is where most people go wrong.
Best of luck
Berni
Best of luck
Berni
berni29 - Fourth Gear
Lou
- Attachments
- extreme JB
- 17124084330511937668901076900615.jpg (57.04 KiB) Viewed 900 times
- to be put on last coat
- 20240406_090317.jpg (48.92 KiB) Viewed 900 times
Louis Lottner
Should be ok provided to got well into the crack with your cleaner and an old toothbrush or ear bud before applying the JB Weld.. Let us know if it's done the trick when you've run it a while !
Previous :-
Previous :-
- elans3
Must be good stuff. According to this blurb from the internet “tougher than steel” . Also good to repair a crack in the control arm on your race car:
“Since their epoxy products dry 'tougher than steel', their use is limited only to your imagination. J-B Weld is great to use in the garage on any of your project cars, however it is just as well suited to various applications around the home for anything in need of some TLC. A handy trick for those who drive their cars to within an inch of their life is to keep some J-B Weld handy in the car. Split your fuel tank on a rock whilst 4-wheel driving or noticed a crack in your subframe or control arm whilst thrashing your beast on the race-track? J-B Weld can offer a strong bond to get you home when replacement parts are not immediately available. J-B Weld has expanded their range substantially since '69 to cover more bases than just their 2-part epoxy solutions, their range now covers:”
Maybe Boeing use this stuff on their aircraft
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Boeing only uses it to seal doors
I was surprised to see the JB, though thats what I would do.
Figured folks knew were were speaking of a Canadian repair, where only duct tape and tie wire are recognized.
Very international
Very international
Love your Mother
Earth
Love your Mother
Earth
Users browsing this forum: ppppatrick, stugilmour and 5 guests
