Diff drive shaft bearing
In the Lotus Elan Service Parts List it lists two inboard drive shaft bearings. Under RB.40 it lists 036 D 6001 and under RB.41 it lists 036 D 6017. Only one drive shaft bearing appears on the drawing. Is 6001 an earlier bearing? 6017 is the same bearing as the rear hub outer bearing, listed under DA.6 036 D 6017, but in the diagram for the differential 6017 bearing appears to have an O-ring seal. Is this also out of date, i.e. are these two bearings the same. Just checking before rebuilding the differential case.
- milton
In the parts book RB40 is the drive shaft and RB41 is the bearing. I've not seen or used a bearing with an O ring on the outer but it is a 2RS bearing, I can't remember the number. It is a common size.
John.
John.
- elanman999
