Castrol VMX80W for gearbox?
PostPost by: skelteanema » Sun Aug 20, 2023 12:57 am
Hi all,
I have seen numerous recommendations for gearbox and differential oils,
I was wondering whether Castrol VMX80W is suitable for the Elan 4 speed gearbox for a road use car that is not driven hard. It is a GL-4 rated oil.
Skittle. 1967 Elan S3 DHC
skelteanema
PostPost by: 2cams70 » Mon Aug 21, 2023 7:32 am
VMX80 works great in the 4 speed. Noticeably improves the shift quality and economical too. You don’t need to waste your money on products where the main differentiator is marketing.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: skelteanema » Tue Aug 22, 2023 5:13 am
Thanks 2cams,
was gifted a 4L bottle. Thought it would be OK but wanted to check. This gives me confidence to change the oi with the VMX.
skelteanema
PostPost by: rgh0 » Tue Aug 22, 2023 7:56 am
VMX80W appears to be a relatively low cost mineral gear oil of the approximate right specification for the Ford 4 speed gear box. Personally i only use fully synthetic oils these days but for a gently used road car it will probably be Ok
PostPost by: 2cams70 » Tue Aug 22, 2023 8:47 am
Unlike a lot of people here I’ve actually personally used VMX80 in a lot of manual transmission cars where the manufacturer calls for a simple straight low EP gear oil. This is the oil that most closely matches the grade specification of the original oil the 4 speed Ford transmission was designed around. It works very well in a hard driven road car. I won’t lie and say I’ve used it in racing though - I’m not wealthy enough for that! Synthetic oils sometimes do not work well with elastomers used in some oil seals. You need to be aware of that.
Remember if a squeaky door hinge only needs a few drops of Singer machine oil to cure the noise it’s not really necessary to spend the money on a synthetic gear oil. Indeed the Singer machine oil may even have a few additives that make it superior to the synthetic gear oil for the hinge application
PostPost by: skelteanema » Tue Aug 29, 2023 9:08 am
I changed the oil in the gearbox with the VMX80. A pig of a job. The old oil still looked good and there was a little over a litre recovered. I refilled to just flowing out the filler plug as recommended and it was about a litre more or less.
I wasn't expecting to notice much difference as I thought the gear change was good on the car. However, it is noticeably better than before, easier to change and smoother too. Exactly as 2cams suggested it would.
skelteanema
