HD Clutch Release Bearing
Hi all,
I have obtained a product known as the HD clutch release bearing.
The left side of the photo is standard and the right side is HD, but the material of the inner ring does not seem to be metal.
If you have used this HD type, please let me know what you think.
Incidentally, the inner diameter of the Standard is 34.5 mm and the HD is 35.3 mm.
I don't have a good impression of loose bearings, what do you think?
Hiro
Hiro
- LCRJ
What's the part number of the RHP bearing you have ? (It should be printed on the box ends).
If it finishes in RS, then that means Rubber Seal, and that's the bit you're saying doesn't look like metal. If the inside diameter is not the same as the original, then it's the wrong bearing, and shouldn't be fitted.
.It will rattle around and do damage to the bearing carrier surface.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
The RHP bearing is the original standard bearing used by Ford / Lotus now called the "heavy duty" bearing by some. I have used them for many years without issues when I have been able to source NOS one like you appear to have got also. The bearing on the left is the cheap non name indian made copy called the "standard" bearing by some. They have proved unreliable and of varying quailty, some last, some do not.
The beaing is suppossed to be a light push fit onto the carrier where the metal section meets the slightly raised section on the carrier base.
The box appears to be printed 6/W 1 3/8 ALVANIA R3?(last letter unknown). The body is stamped ENGLAND 6/W 1 3/8.
This is the first time I have found out that these are HD as they are genuine Ford and Lotus parts.
The one on the left is not stamped with anything. I have been using this one and have had no problems with it, but for some reason it turns lightly when pressed against the CARRIER and becomes heavier when released.
As you say, the base of the carrier is tapered so it fits even if the inside diameter is a bit larger.
Thank you.
Hiro
Thank you.
Hiro
- LCRJ
Just for reference here is my full ist of part numbers all original ones are obsolete so you are chasing NOS on Ebay
Elan 4 speed clutch thrust release bearing
Note : this is the flat face bearing used on Anglia and Mk1 cortina
Flat face onto platten on clutch plate spring fingers
Original Manufacturers
Number Comment
Ford 105E7580 obsolete Ford used RHP as supplier for this bearing as OEM
Ford 105E7580B not sure what the B meant, maybe different OEM supplier
RHP 6W 1 3/8 obsolete, have NOS sample
FAG 508458 obsolete, NOS sample ex Ebay .. World wide autoparts in stock still?
Timken 1375 obsolete, No NOS located, big Timken cross reference list, no
sample
FKC 6W 1 3/8 obsolete ? According to Daiwa who bought FKC , NOS at Orinoco / FKC bearings UK
SKF 408504 obsolete I have used but have no sample, NOS listed on internet from time to time
Current Manufacture
Orinoco / Hoffman / RHP 6W 1 3/8 current, small specialist UK, expensive, sample labeled "england" "6W 1 3/8" box "RHP"
No Name no number current Sold by Ford / Lotus parts suppliers - suspect reliability, have sample, some etched on face 405804
Smaller obsolete rebranders and manufacturers
A-1 Clutch Co B49010 obsolete, listed on Timken cross reference equivalent Timken 1375
AP HD3257 obsolete, listed on Timken cross reference equivalent Timken 1375
Beck - Arnley 0620211 obsolete, listed on Timken cross reference equivalent Timken 1375
Beck - Arnley 0620617 obsolete, listed on Timken cross reference equivalent Timken 1375
Beck - Arnley 0620611 obsolete, listed on Timken cross reference equivalent Timken 1375
Beck - Arnley 0620625 obsolete, listed on Timken cross reference equivalent Timken 1375
B-W N3740 obsolete, listed on Timken cross reference equivalent Timken 1375
European Parts Exchange 741 obsolete, listed on Timken cross reference equivalent Timken 1375
Green CB 2008 obsolete, listed on Timken cross reference equivalent Timken 1375
L&S TT2008 obsolete, listed on Timken cross reference equivalent Timken 1375
Nice N1841 obsolete, listed on Timken cross reference equivalent Timken 1375
Pioner N2035 obsolete, listed on Timken cross reference equivalent Timken 1375
Quinton Hazel CCT24 obsolete, listed on Timken cross reference equivalent Timken 1375
Seal Power C4088 obsolete, listed on Timken cross reference equivalent Timken 1375
Number Comment
sample
Current Manufacture
