Tailshaft oil seal to prop yoke
PostPost by: MartinH » Thu Apr 13, 2023 12:06 pm
Hello
I'm just about ready to start my engine after removing it to replace the gearbox and all the usual things relating to bottom end oil leaks. I was about to start it to check for oil leaks but havent installed the propshaft yet and it occured to me that it will probably pour oil out of the gearbox tailshaft without the propshaft yoke being properly fitted. Am I correct and I do need to install the prop first?
Martin
1967 Elan convertible S4 body and Spyder chassis
Ducati Monster S4
Ducati 1098s
MartinH
PostPost by: elancoupe » Thu Apr 13, 2023 1:31 pm
Yes, oil will come out without the prop shaft being fitted.
elancoupe
PostPost by: MartinH » Thu Apr 13, 2023 3:07 pm
Thanks Mike.
I definetly won't be doing that then especially with the price of the Redline gear oil.
Martin
Ducati Monster S4
Ducati 1098s
MartinH
PostPost by: pharriso » Thu Apr 13, 2023 4:24 pm
Why don't you leave the gearbox in Neutral? :?:
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: 2cams70 » Thu Apr 13, 2023 10:59 pm
pharriso wrote:Why don't you leave the gearbox in Neutral?
Even with the gearbox in neutral the input gear, laygear and mainshaft gears are all rotating and churning oil. The only way to be sure the gears have stopped would be to the hold the mainshaft stationary, disengage the clutch and have the transmission in gear. Note by just disengaging the clutch you can't guarantee the gears aren't still turning because there may still be light drag of the clutch plate against the flywheel or pressure plate facings.
Without the propshaft fitted you can't easily hold the mainshaft stationary.
In summary - just fit the propshaft!
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
