Gearbox identification help.
PostPost by: elansprint71 » Tue Apr 04, 2023 1:38 pm
Can anyone tell me what these gearbox casting numbers indicate: 2824E 7006C please? I don't know what type of Ford it came out of.
I think(!) it is a 2000E single-rail gearbox, It is fitted with a long ally tail housing with the gear-shifter right on the end. I'm having trouble separating the tail-housing from the box, it comes about 8mm out but then there is clearly something stopping it!
Any help and advice much appreciated.
Pete.
PostPost by: 2cams70 » Tue Apr 04, 2023 1:58 pm
It's a late Mk2 Cortina or Mk1 Capri box. Could have either standard or semi close ratios.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: elansprint71 » Tue Apr 04, 2023 6:31 pm
Thanks 2cams. :D
PostPost by: joe7 » Tue Apr 04, 2023 8:40 pm
Last time I did one of these was last century and I muddled my way through it! I' ll take a shot. I think you will need to remove or disconnect the shift rod from the forks. Also, I remember there is a large snap ring holding the MS. So good luck!
joe7
