Play in gear stick and feels a little vague and loose
Hi Gents
I’m new to forum as off yesterday, Have enjoyed reading posts, lots of knowledge here I can see, I have purchased a 69 plate +2 which is in pretty good mechanical condition. Could I ask for some advice please, my 4 speed box feels just a little sloppy, I can find all gears positively but float between gears is loose and stick is a little all over the place before I select gear, can someone suggest what I could do to tighten it up, I did consider a quick shift option from Kelvedon but not sure if that help. Any advice is much appreciated.
Thanks in advance
Jason
Thanks in advance
Jason
- JasonJ
check the anti sizzle bushing. Gary
- GLB
Cheers Gary
Will check it out.
Thanks for reply
Will check it out.
Thanks for reply
- JasonJ
Yes, check out the sizzle bush and also check the nylon cap is not winding it's way out.
A loose nyloc or roll pin on the gearstick is another possibility.
- jono
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
Thanks Gents
It was a split pin in where a roll pin should be just below the nyloc nut, managed to get correct size roll pin. Back to how it should be.
- JasonJ
