2.5 close ratio gearbox
Al - this is a picture I took when rebuilding the CR gearbox from my 65 Seven. I was taking a spare box apart for cleaning/sorting at the same time. I'm pretty certain the CR set is the bottom set, bit need to count teeth to confirm.
Not sure if this is what you need, but if something else I can search through my pictures of disassembly and reassembly.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
SENC wrote:Al - this is a picture I took when rebuilding the CR gearbox from my 65 Seven. I was taking a spare box apart for cleaning/sorting at the same time. I'm pretty certain the CR set is the bottom set, bit need to count teeth to confirm.
Henry,
What can I say other than that's exactly what I needed and thank you very much! For some reason, of the 2.5 gearboxes I've done I've not taken a photo of all the parts disassembled and displayed like that.
I wanted to confirm I wasn't going mad as someone has brought me a gearbox to assemble and it doesn't have all of the correct gears - I needed to show them that I wasn't talking nonsense but didn't have a comparison!
As you say, the CR box is the bottom one of the two.
Kind regards.
Al / Ron
promotor - Fourth Gear
