bell housing hole?
Ok, possibly the stupidest question ever asked but it has been a cold and damp day and I have no mental energy left, so my apologies.
Opposite where the starter motor goes, there is a hole in the back of the bell housing, as if an opposite starter motor could be fitted.
What goes in that hole?
Thanks!
Thanks!
- Bitsilly
The bendix of an inertia type starter protrudes through that hole and is covered by a cup shaped metal cap which is a press fit into the bellhousing. It's a Ford part suitably reshaped to clear the chassis in the Elan.
S4 DHC
S4 DHC
- oldelanman
There are two sizes of that cover and the one you need is difficult to find.
I failed to find one and I temporarily botched it up with the bottom of a plastic bottle. Once painted black it looked OK and kept the dirt out.
Some time later after fitting a new high torque starter motor, the extended cover was no longer needed and I found the lid off a tin of brass shim fitted perfectly.
Good luck
Eric in Burnley
1967 S3SE DHC
Good luck
Eric in Burnley
1967 S3SE DHC
- ericbushby
Leave it open, then when the Starter Bendix jams you can put a Spanner on the Starter shaft to release. 7/16" Spanner.
- alan.barker
alan.barker wrote:Leave it open, then when the Starter Bendix jams you can put a Spanner on the Starter shaft to release. 7/16" Spanner.
The square for the spanner is on the other end of the shaft I believe ... no need to leave the bendix cover off for access.
S4 DHC
S4 DHC
- oldelanman
yes you're right i had a brain wobble dohhhh
- alan.barker
Here are pictures of the 2 I have - they are the same size - right at 2.25" diameter. I started reforming 1 of them to see if I could get a fit on my Seven and will say these don't deform easily. I'd be happy to share either one if you are interested.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
