LAYSHAFT PAINT
I've just finished refreshing the Gearbox on my Sprint.
On the Layshaft it had yellow paint and wondered why.
Could someone suggest why
- alan.barker
I'm only guessing but it could be easy identification for production workers to determine
into which gearbox it gets installed, ie, wide, semi close, close.
Greg Z
45/0243K Sprint
36/5727 pre airflow coupe
45/0243K Sprint
gjz30075 - Coveted Fifth Gear
Is it definitely semi-close ratios? I've just looked through some photos of semi-close gearboxes I've overhauled and I can only find one cluster with paint on and that is orange.
Before I went looking my first thought was that yellow may be for wide-ratio, although I'm not 100% sure on that...
promotor - Fourth Gear
As far as i know i'm the first to refresh the Box. Maybe i should get my marker out and count the turns in first Gear.
Is it one turn output and count input turns.
Sorry i'm a gearbox virgin.
- alan.barker
alan.barker wrote:As far as i know i'm the first to refresh the Box. Maybe i should get my marker out and count the turns in first Gear.
Yes select first gear and turn input shaft three times to get one on the output with semi-close. Wide ratio is 3.5 turns of input shaft to 1 turn of the output in 1st.
I have to say the gears look to be semi-close looking at the size of the gears but photos can be deceptive!
Just counted in first and i have 3 turns. So happy it semi-close ratio.
Many thanks you had me worried. I think i'll just take a glass of cabernet sauvignon to celebrate.
Tomorrow Box goes back into "Little Lo"
- alan.barker
alan.barker wrote:Cheers,
Glad to know you've got the right gearset. I'll definitely be looking for paint marks on gears on the next gearboxes I strip!
