Which clutch arm
following on from the topic on bell housings, which of the different clutch arms are the correct on to use with the Anglia bell housing.
Also somewhere I think I tread that the pivot pin is also different so again which is the correct pin?
Tony
Tony
- tonyabacus
The correct arm is the MK 1 Cortina one. It’s the same as was used on the regular pushrod OHV models. Mk2 Cortina is different and won’t fit’
The correct pivot pin again is the MK 1 Cortina one. The Anglia pivot pin and arm is different and not correct for a Lotus.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
