Gearbox ID and tags
Found a gearbox whilst having a sort out which appears to be a 2000E, checked ratios by checking input/output number of turns. The ratios appear to be consistent with the semi close ratio set, with a input shaft diameter of 15mm.
There is a tag on the box which is very corroded and very difficult to read, but from what I have can anyone decode the tag please,
Top Line; 20?2 PEZ (the first four digits are barely readable as is the letter P, so these are as close as I can get)
Second Line: 7? E?23 (there may not be a number after 7 and E, the corrosion is to bad to see)
Tony
Tony
- tonyabacus
