Gearbox Tailshaft swap
Found a 2000e type gearbox when clearing out and wonder whether this can be modified to fit an Elan by changing the tailshaft housing, for the housing on an early Cortina or Anglia box that has the long pudding style gear lever arrangement.
Anyone done this?
Tony
Anyone done this?
Tony
- tonyabacus
https://105eoc.com/?v=79cba1185463
Article is "gearing up for a change" For some reason copying the link to the page is taking me back to the site home page.
It is in the technical articles.
If i am understanding correctly what you are after, this may help. Read above by the van man. Saves a lot of explaining. Nice article.
Tail cases have different bearing carrier depths to accommodate the early and later bearing carrier arrangement and improved oiling of the rear bearing.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Hi Mike
Thanks for the pointer, very informative mod write up.
The query it leaves me with is the length of the tailshaft housing, clearly the 997 Anglia box and tailshaft are not suitable which leaves the question about the Cortina/Anglia 1200 box.
Does anyone have any info in that respect or does anyone have a Cortina 1200 box to measure the length of the tailshaft housing?
Tony
Tony
- tonyabacus
Yes, it can be done but a bit involved, mainly due to a modified, thicker, rear bearing carrier on later box.
Should find this post of interest.
viewtopic.php?f=37&t=47631&p=345227&hilit=+Quaiffe#p345227
Quaiffe data sheet covers using ‘ old style ‘ case with the later main shaft, it’s all there if you study it carefully.
- Craven
Thanks Craven, Rohan's article answers perfectly what I needed to know
Tony
Tony
- tonyabacus
