early vs late synchro hubs
Hi all, I'm rebuilding my gearbox (again) and have found some damage to my 1st/2nd synchro hub.
It's a 66 car so has the early type gearbox.
I seem to be able to find late version synchro hubs for sale but not early version. Does anyone know if the two are interchangeable? perhaps with a synchro ring swap as well?
cheers!
-jim
cheers!
-jim
36/6612
1967 S3 Coupe (left the factory in 66)
original rego PPC 8E
original owner B.M. Wetherill ..are you out there?
dgym - Third Gear
thanks nmauduit
so if i get myself a complete new version hub assembly with blocker bars and synchro rings for each side I'll be good?
Edit, completely misunderstood your post!
36/6612
dgym - Third Gear
Jim - I found them a few months ago. Let me see if I can find my receipt and correctly identify where I found them and I'll post later today
Found my receipt - sjsportscars - just checked their website and they are still listed. Good luck!
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
dgym wrote:I seem to be able to find late version synchro hubs for sale but not early version.
fwiw, I see both kinds offered by Burton for instance (no affiliation), maybe you should search under Ford 2000E gearbox? it seems that the early version is more expensive than the late, at least from that supplier (I'm sure there are others, though would personally never again deal with someone from Crediton on anything about gearboxes)
S4SE 36/8198
nmauduit - Coveted Fifth Gear
If the hub assembly is on Burton's page i must be blind or crazy!
the damage is: absolutely destroyed blocker bars and destroyed out outer hub section. It's unusable.
36/6612
dgym - Third Gear
i've found this one but no mention or early or late. would there be an obvious visual way to recognise (i've emailed them but it's the weekend)
https://www.bearingkits.co.uk/details.asp?ID=1744
36/6612
dgym - Third Gear
I would have to dig through my parts but i think I have a 1/2 syncro hub for an early gearbox. My last gear box build with Quaiffe gears was based on an old box and i could not use the 1/2 hub due to the differences with the later style shaft that Quaiffe supply.
