Hot gear lever/air blast
Doing some dash work and currently driving without the centre console in place. Noticed that the hole in shell for lever to poke through is like a hot hair dryer and blasts heat into cab. Gear lever also very hot. Is this standard?
I guess I need to check gearbox oil etc but wondered if normal .
Ta
Ta
- Mileso
think so
exhaust is right there, posts about clutch line being too hot rendering clutch useless etc.
Love your Mother
Earth
Love your Mother
Earth
Certainly notice the gear lever on my S4 getting hot on a long run in warm weather. The whole central area around the gearbox gets warm eventually as well - you can feel it through the carpet. My guess has been it’s hot air from the exhaust (it gets warmer on the exhaust side) and the radiator blowing back.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Not sure which car you have, but in my Plus 2 the hole in the body is sealed by a square of rubber sheet that has a 'spigot' in the center that fits around the shift-ball and is secured to the body by a square ring of sheet metal around the edges and some screws into the GRP. Driving around with no console or other interiour trim installed, I found that this bit of rubber stopped a lot of hot air and a fair amount of noise too.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
On my S2 the tunnel gets really hot, and once or twice the shift boot has blown out letting a torrent of hot air through. I know the exhaust gets the blame, but it seems to me to be all manner of engine heat blowing down the tunnel and onto the rear end before finding a way out. Isn't is some 1/3 of the engine heat goes out the radiator, 1/3 the tailpipe and 1/3 move us along? I think it's the radiator.
Anyway, dreaming of a way to reduce it, it seemed perhaps a rubber flange in the tunnel reducing the passage of air might stop it. Or fitting a rear duct to the radiator to direct the output down as in an Eleven.
But I'd expect the shift lever to get hot no matter what from the transmission.
It's possible, btw, that the blast down the tunnel helps the diff stay hot.
- baileyman
The Veg wrote:Not sure which car you have, but in my Plus 2 the hole in the body is sealed by a square of rubber sheet that has a 'spigot' in the center that fits around the shift-ball and is secured to the body by a square ring of sheet metal around the edges and some screws into the GRP. Driving around with no console or other interiour trim installed, I found that this bit of rubber stopped a lot of hot air and a fair amount of noise too.
Mine was missing this bit, and I made a poor mans version from some insertion rubber. Made a big difference!
Elan +2 #0245
Exige S2 Supercharged
Elan +2 #0245
- Chrispy
Hi Miles,
I realise that you are asking about the temperature of the air that blows through the gear lever hole, and all of the comments as to why it is hot are relevant.
However, with your console removed, the rubber shift boot (gaiter) should still remain in place, and you should not be feeling any blast of hot air. There should be a flat coverplate, held down with 4 self tappers, attached to the transmission tunnel. The plate has a large hole in the centre, and the circumferential slit at the bottom of the rubber shift boot fits into this hole forming an airtight seal.
Gaiter:https://www.sjsportscars.com/parts-and-accessories/A036B6186Z.htm
Cover plate:https://www.sjsportscars.com/parts-and-accessories/X036B1038Z.htm
If you are aware of this, please ignore all of the above.
Colin.
Colin.
Mileso wrote:Doing some dash work and currently driving without the centre console in place. Noticed that the hole in shell for lever to poke through is like a hot hair dryer and blasts heat into cab. Gear lever also very hot. Is this standard?
Ta
'68 S4 DHC
- fatboyoz
Has any one a photo of this rubber sheet? I have the metal that holds it in place and a nine correct rubber gaiter but have never seen the rubber sheet.
Thanks.
- mbell
Colin.
Thanks Colin - i do have the metal plate so will try to link the gaiter to it (was previously just into console). I am going to add some heat resistant material to for 'belt and braces'!
Colin.
- Mileso
Possibly an old wives tale, but I have seen it suggested that the inner rotoflex is much more likely to fail than the outer - due to a combination of temperature (hot air down the transmission tunnel) and oil contamination (leaks).
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Users browsing this forum: maltese falcon and 20 guests
