U-joint issue
I'm replacing both u-joints of the prop-shaft using NAPA UJ341 with their circlips, same thickness as the original, ~.060". I had checked the MOOG website and it actually lists the '65 Elan and calls out their 341 product. However when I install one of the clips and push the other end up against it I can't install the opposite clip. I see there are .040" thick clips available which would solve the problem but that might cause some offset imbalance. Has anyone experienced this, solution?
Jerry:
'61 S2 Elite | '69 S4 Elan FHC | '00 S1 Elise Sport 190
jabingb - Second Gear
Ignore this, nudged the ends back forth a tad and the circlips fit with nice freedom of motion, that is on one axis, still working on the cross, will tackle that in morn but I believe I'm on the right track.
Jerry:
Ran into the same issue of getting the second circlip fully seated in the u-joint. This occurred when fitting the T9 yoke for the Voigt 5speed conversion. Spent a lot of time on this. Finally just filed a thou or two off the circlips on either side. I got reassurance that this was OK from others.
BTW, I used a Spicer u-joint. Much more robust needle bearings and made in the USA (I believe).
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Users browsing this forum: ianthomson72 and 20 guests
