4-Speed drain/fill plugs?
I decided to change the oil in my gearbox, since I'm unsure of its quantity or age. It took a MIGHTY struggle to get the drain plug loose and almost as much to remove the fill plug. After cleaning them up, I see that they are tapered iron pipe plugs. Are these the correct items?
1969/70 Elan Plus 2 (not S) 50/2036
The Veg - Coveted Fifth Gear
Yep, look like it to me. Hollow, not solid..
mark030358 - Fourth Gear
I’ve got a small leak from my drain plug even though it’s torqued to specs.
I have about 3 threads exposed, is that typical ?
'72 Sprint
'72 Sprint
- richardcox_lotus
Hi Richard
Those tapered pipe threads really need PTFE tape on them. Did you do that. Back in the day they used a cotton fibre and a sort of putty on those threads. I cannot remember it`s name now but I still have some in the shed.
Eric in Burnley
I`ve just remembered it. It was called Boss White and Hemp. Night, night.
Eric in Burnley
- ericbushby
Definitely correct, those are them...
Mine were difficult to remove also.
Not sure why they get done up so tight, especially as they're tapered and tend to widen whatever hole they're going into.
I'm always cautious as I'm concerned I'll be giving them that last little tighten and I'll hear, "click", and find the crack in the gearbox casing.........
Ralph.
Ralph.
- reb53
Thanks Eric, I’ll add that to my notes.
'72 Sprint
'72 Sprint
- richardcox_lotus
It helps to have the right tool, which I lack, and my level/fill plug wouldn't shift with non-tapered spanners having suffered that 50 times already. Luckily St Wilkins lent me his proper tool (he's five minute drive away) and also sold me a new plug so now I'm good for another 50.
Meg
I find that my drain plug leaks as well and the square has slightly rounded over the years. I am surprised that no one has come up with a better solution, or if they have, I am all ears. Thanks, Dan
As it's a standard NPT size, you can source a tapered pipe plug with various head types from many sources. I found an internal hex (allen type) plug with magnet insert to replace mine. From Pegasus Racing Supply, if I recall correctly.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
I use an internal hex magnetic for the drain plug and a brass plug for the fill plug. Brass works out very nice as is a bit softer the the steel plugs and won't rust. Also rather than plumbers tape I opted to use plumbers paste type sealer as i fined it easier to use.
- joe7
bitsobrits wrote:As it's a standard NPT size, you can source a tapered pipe plug with various head types from many sources. I found an internal hex (allen type) plug with magnet insert to replace mine. From Pegasus Racing Supply, if I recall correctly.
.... in the INSTRUMENTS Accessories and Fittings section (Page 272 in the 2015 edition).
Meg
We are supposed to be having fun, are we not?
- USA64
Personally I've never had any issue with the standard Ford plugs. No leaks and no teflon tape required. On live rear axle Fords similar tapered iron/steel plugs are used. Again no leaks and no teflon tape required.
Often oil drips appearing at the bottom of the gearbox are from other sources - eg. engine rear main seal or the lower through bolt joining the gearbox to the bellhousing.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2015 Honda City 5spd.
- 2cams70
2cams70 wrote:Often oil drips appearing at the bottom of the gearbox are from other sources - eg. engine rear main seal or the lower through bolt joining the gearbox to the bellhousing.
Good point. The drops hanging on the gearbox drain-plug looked brown, but what drained from the 'box was dark grey, a little murky, and stunk of sulfur. Definitely different stuff.
No real problem with either of the plugs on mine but looking at them someone previous had had problems as the corners were a bit chewed up. Probably overtightened at some stage! Quick fettle with a file to restore the square while I was changing the oil and they are fine, no problems with leaks from the plugs themselves.
- Bigbaldybloke
