Universal Joint clearance
Hello all.
Just fitting new UJs to my propshaft.
They came from a lotus specialist.
As per photo there is very tight clearance on the grease nipple. It's screwed in as far as possible, and there is even less clearance if fitted the other way up.
It allows for some movement, would this be enough given there's (I guess) very little displacement of the propshaft.
Are these wrong for the job?
Dave
Dave
- dlb123
Would have thought the grease nipple should be 90° not 45°
https://www.ebay.co.uk/i/392516162028?chn=ps&var=661503065669&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=661503065669_392516162028&targetid=908661474856&device=c&mktype=pla&googleloc=9046270&poi=1006806&campaignid=10199419126&mkgroupid=101401894545&rlsatarget=pla-908661474856&abcId=1145984&merchantid=6995734&gclid=CjwKCAjw26H3BRB2EiwAy32zhensfoksOvfhoPtEBMwsw6eDQaZustfq6htzdK-tvLQ4cpAVgetJWRoCvNoQAvD_BwE
Elan S2 DHC (26-4399),
- Barney
It is a tight fit to get the grease gun tip, to connect between the bearings.
I have used the Grease Rejuvenator to get access though the service plug, beside right seat in tunnel.
Some kits come with a plug, which you add whatever nipple you choose. Though, its such a tight space. Might be impossible to do?
Mine is a very short, straight nipple. So a 90 makes sense!
Love your Mother
Earth
Love your Mother
Earth
If you closely you should see a very small scallop/chamfer to give clearance for grease nipple.
- alan.barker
MarkDa wrote:rgh0 wrote:I normally just fit a plug and only screw in the grease fitting when I want to grease the UJ
Racers and weight saving
Yes reduction in rotational mass is especially important . It also makes greasing easier as I screw in a long fitting which makes getting the grease gun on easier in the confined space through the access hole or just in front of the diff.
I do exactly what Rohan reported - my U-joint grease nipple left very little clearance. There isn't a lot of angular movement with these driveshafts, so greasing interval is longer than with typical installations.
elangtv2000 - Third Gear
