gearbox selector forks
My 3/4 selector fork is worn considerably more than 1/2. Is this normal?
Thickness for 3/4 is 0.178"
Thickness for 1/2 is 0.231"
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Yes, this is quite common. Mostly on the 4th gear side, where under long highway cruises, the fork continues to hold the hub in engagement.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
They almost always wear on 4th side (and not really on 3rd) but yours is particularly bad.
If you want to repair it you need to find a capable welder who can repair it without melting /warping it. Then, getting it back to flat - ie tidying up the weld / braze - is the part that requires attention to detail as they can end up out of shape quickly!
I've re-claimed plenty as I believe it's nice to save old ones rather than just buying new.
However, the cost of a new one isn't that much and seems much better value if you factor in time spent and materials to make an old one new again!
promotor - Fourth Gear
Thanks Roger. Thanks Al.
More wear in 4th makes sense and I will purchase a new selector fork.
67 Elan +2
67 Elan +2
- seniorchristo
Chris,
Check the syncro hub, input shaft and syncro ring too for wear on the little engagement teeth. They will also wear, especially if the gearbox has been jumping out of gear for a while.
Some of these parts are getting hard to find, worst offender being the input shaft. Because it must be paired to the laygear and be the correct one for your ratio set.
'67 Elan S3 SS DHC
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
4th gear synchro is quite worn while 3rd looks fairly new. I haven't been able to press the rear bearing off yet to access 1st and 2nd synchros. Everything else looks great except reverse gear which is pretty chewed up. I'll be looking for a replacement
67 Elan +2
67 Elan +2
- seniorchristo
