speedo drive
How easy should it be to turn the right-angle drive in the gearbox.
- AussieJohn
You won't be able to turn the inner cable drive by hand, if that's what you are asking. The inner drive gear on the speedo drive is in mesh with the output shaft of the gearbox, so if you try to turn the central shaft (where the cable inserts) you are trying to rotate the entire gearbox via that very small shaft. Not recommended.
But by putting the gearbox in gear and turning either the input or output shaft you should see it turn. Or just remove it to check it out. Will give you an opportunity to reseal it, as they are prone to leaks if not properly 0-ringed and gasketed.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Sorry, I didn't explain myself well, I meant turning the whole right-angle drive in the gearbox; should the clamp hold it very firmly to the box or should it pivot freely? cheers, John.
- AussieJohn
Thanks John, how is that mighty traveller going?
- AussieJohn
Just picked up a spare empty back axle ( Escort Mk2 ) am thinking of giving the back a little toe-in ( remember the Trapezoid ? ) , the problem being the half-shafts then not being at 90 degrees to the output gears??
Good old Colin used lots of rubber to allow movement , what was it he said " a pound of rubber is worth ?100 of engineering" , or something to that effect ?
