Isuzu 5 speed...again
• Page 2 of 3 • 1, 2, 3
It's a cold day here (28 degrees) but clear and sunny. I needed to take a ride and visit my machinist. Life is short and neither of us is getting any younger. I was looking forward to seeing him and taking him to lunch.
Guess what? He is one vacation with his wife. A cruise none the less. Well he deserves it and his wife always puts up with his shenanigans. He's a marine so you can imagine! He'll be back next week.
The good news! The CNC operator couldn't find the program and neither could the manager. Luckily, they let me sit down at the computer. Viola! I found the program and my invoice from 4 years ago. Where does the time go? More importantly, the program is safe and when Harry gets back next week, we'll have a price. I should have made a few extras years ago when Aluminum prices were substantially lower.
I'll have a price on the adapter plates next week.
While I'm waiting, I think I'll visit my other fabricator and machinist friend Bob and let him cut off the bellhousing on my spare trans that came out of a Isuzu pick up. Greg Zelazak was with me when I purchased the second trans. I remember I was told someone else already had dibs on it. I found the yard manager, told him I had some cash with me and asked what would it take for me to take it with me. A moment later, he got another yard worker to remove it and it put it in my truck. They are not easy to find.
Frank
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
Has anyone considered an alternative way to achieve the same thing? An overdrive.
There is a US company offering a pretty small, VERY expensive but highly rated unit that is roughly 7" deep, radius of 3.25" and about 12" long. If it is not possible to fit it to a shortened tail housing then I guess it could fit behind the tail shaft in the tunnel. The unit is a 0.78 and runs about $3,000.
Or is this heresy?
Or is this heresy?
Richard Furse
Funemployed in N Wales
S3 DHC
S4 DHC
S4 FHC
S4/Sprint
340R
SID
14 "others"
S3 DHC
S4 DHC
S4 FHC
S4/Sprint
340R
SID
14 "others"
- rcfurse
Yes, it's gearvendors.
https://www.gearvendors.com/install.html
They say "it's roughly the size of a coffee can".
Richard Furse
S3 DHC
S4 DHC
S4 FHC
S4/Sprint
340R
SID
14 "others"
S3 DHC
S4 DHC
S4 FHC
S4/Sprint
340R
SID
14 "others"
- rcfurse
Davidb,
They say a picture is worth a thousand words. That one exceeds a thousand. Good pic.
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
It would be a wonderful solution-if it fitted. That way we would retain the wonderful feeling of the standard gearbox but with the addition of o/drive (On 2nd third and top?!)
The overdrive pictured is a Laycock de Normanville (GearVendors unit is a copy) unit-actually from a Volvo. If you want a cheap overdrive go to your local Volvo wrecking yard. It isn't that simple-you have to make up a blanking plate for the front and find a shaft-probably from an old Volvo gearbox-to drive the unit. But it can be done-given enough room...
But not in an Elan.
But not in an Elan.
'65 S2 4844
- Davidb
That box was originally in the Isuzu Gemini (Holden Gemini here in Australia). The Isuzu Impulse (Holden Piazza) was basically the same platform. Don't confuse it with Geminis built from the mid 80's because by that stage the switch was made to front wheel drive. Some of the Isuzu pickups and SUV's may have shared a similar box but I cant be sure without research. In my workplace I actually have access to a lot of the old Isuzu workshop manuals. I saved them from being trashed so they are still in the archives somewhere - yes even going back to the Bellet !!
https://en.wikipedia.org/wiki/Isuzu_Gemini
https://en.wikipedia.org/wiki/Holden_Gemini
https://en.wikipedia.org/wiki/Isuzu_Piazza
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Hmmmm, yes, the rarity these days of Isuzu bits in the USA is a concern for trying this, and any attempt by me to install a five won't be for a little while yet, which doesn't help with that rarity. Maybe some of the other possible boxes would be better to plan for.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
I am in Australia where the Izusu/Holden Gemini was very popular. Sadly most have been scrapped and these boxes are harder to get. I was lucky to find the diesel box after a short search. Gemini's are now popular for putting rather larger motors than was previously envisaged. https://www.flickr.com/photos/aussiefor ... 340445950/
The notion of the adapter for the gearbox side saves a vast amount of work if you can get two flat (compatible surfaces) I think. I am going to use this method in the Porsche 944/V6 project I have.
One warning is the location of the speedo drive. It is very close to the bulkhead in the frame and there is a mod that neds to be made to shorten it. You can screw the Elan cable to the drive. The ratios are quite similar but you will need a speedo redo to get it accurate.
Here are a few photos. Took them so I could remember how I did it. Putting in and removal is not a job to be taken lightly. I had to do it a few times to get it all working correctly and that was with the body off!! I found it easier to undo the whole lot half way out. The engine to bell housing bolts are very difficult to get at.
- Terry Posma
Any issues with speedo drives should be moot, at this point in time, with advent of the GPS
speedo box, discussed in recent threads. Your stock speedo cable will screw into the GPS
'black box', hidden, or in plain sight somewhere in the car which allows you to retain your
stock speedo gauge and innard workings.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Years ago around 2002 we converted a Alpha 5 speed into my Plus 2. Still driving it today with no issues (knock on wood), My car has a 1700 cc Webber motor dynoed at a about 130 bph driving a 3.55 diff. In archives there is a lengthy discussion of the build, installation, and critique by various contributors, for what it's worth follow this thread:
lotus-gearbox-f37/speed-conversion-t14379.html
Rick Cranshaw
Rick Cranshaw
- crannyr
