Gearstick types ?
I'm thinking of buying a second gearbox as mine has a whine and it's possibly cheaper than a rebuild.
Thanks for any advice
- Concrete-crusher
Yes it will fit. The later type has a two-part lever joined by a rubber bush to prevent noise being transmitted into the gear lever from the box. The solid lever gives a better feel to the change, in my opinion.
Nigel F.
Nigel F.
- nigelrbfurness
I have to agree. The difference in shifting between my S2, with a solid stick, vs my Plus2 with cushion, is significant. On my list is to construct a new solid shift lever for the Plus2. Can always change back if I do not like the change.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
In my opinion the +2 gear selector is the better of the two bushed types, i'm sick of my 2 seater gear selector as i have already snapped one lower section and what i consider 'tight' still loosens if i'm slightly aggressive selecting gears plus i have a Sue Miller bush fitted and it feels too soft and vague.
So for me i'll end up with one of these https://www.tonythompsonracing.co.uk/pa ... el-billet/ only reason i've not pulled the trigger already is i was hoping for a chrome version to save messing about and i was a little worried about it rattling.
Grizzly - Coveted Fifth Gear
I prefer solid sticks, they do sizzle at some resonant frequency though, but nice and positive.
You can mod old Anglia or Cortina sticks for the cost of some patience, heat and use of a lathe.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Small world....... I was just watching a Harry's garage and he seem to like the solid selector too
https://www.youtube.com/watch?v=oIqyIO8NWYc (2.37 if you don't want to watch it all)
Looks like a Tony Thompson even though he says he had it done at Paul matty.
[*]v
On a twin can Escort the gear lever is solid but where it locates in the selector lever there's a nylon bush (which often breaks and disappears into the inards or the box). Never had a problem with sizzle if this bush is in place. Keeps the shift tight too. Becomes a bit sloppy if it's missing.
miked wrote:I prefer solid sticks, they do sizzle at some resonant frequency though, but nice and positive.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Yes, plus more levers to move to the tail area. Elans and Anglia and early Cortina is straight in the box with metal half ball. Also end of mech has a flat. Remote integral has that nylon bit and end of lever has a ball end.
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Hello
I think you mean:
Urs
ElanDNA - Second Gear
Not seen that before. You live and learn. I thought you were talking about a remote integral. Is it still available. I always thought an Escort lever was further back with remote integral.
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
I had a look in my box of gearbox bits and found the little nylon device that I thought was a washer. When cleaned a little it is the nylon device shown with the red arrow. Has a little spigot to locate in the metal cup and prevent metal to metal contact
I will be fitting it to see how it behaves. Mike
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
I have been enquiring about the washer and best i can come up with is this http://www.kelsport.net/parts/product_d ... ctionID=27 might get one and see if it makes any difference.
