Top diff mounts - are they usually this difficult to get to?
I have now replaced top diff mounts with Kelsport heavy duty race mounts and have the diff back in place after breaking a drive shaft so fitted Tony Thompson solid steel ones.
I have not yet tightened the top mount bolts or the torque rods. Is there a correct sequence - i.e. tighten diff top bolts first and then tighten torque rods ?
Coupe - Second Gear
Yep, that's the way I did it initially although I later fitted a brace to the diff so only undid the top mountings to do that and had no problems. Just check the clearance between the bottom of the diff housing and the chassis when you fit the diff brace, you may need thinner washers or in my case I machined 1.5mm off the tube through the mounting as I only had one washer fitted originally so couldn't remove that altogether.
- Bigbaldybloke
