Early gearbox - machining to first motion shaft
I have an early semi-CR gearbox that has been refurbished but I gather the first motion shaft needs to be machined to mate with my later engine - can anyone advise and also maybe recommend someone who can do this?
I am based in the Midlands, UK.
David
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
1965 S2
1966 S3
- dunclentdr
I think this is the type of bearing that needs replaced to suit the size of shaft?
http://qedmotorsport.co.uk/qed-shop/lot ... bolt-crank
A good tip I got, and it works, pack the old bearing with grease and tap an object the same diameter as the hole in to the grease ( I used a valve grinder - the rubber sucker fitted great) the hydraulic pressure pushes the bush out.
George
George
- Type28
I'm 90% sure that all semi-close input gears (2.97:1 first gear ratio) should already be sized to suit the 6 bolt crank with needle roller bearing (smaller diameter). They were introduced in 1967 at the same time as six bolt cranks were adopted on all pre-crossflow motors
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
