Close ratio value??
Mazzini wrote:I run a close ration box in my S3 with a 3.5 diff. The car has a 135bhp engine and it's a pleasure to drive, yes it lacks the "squirtability" of a low geared Elan, but then the car will cruise on motorways at 80mph+
If that doesn't appeal why not try a fitting a 3.7 dif?
I picked up a 3.7 diff before the idea of semi close and 3.55's came along....I'm leaning towards that. Not much different than 3.9 but on today's roads a little bit helps.
Kurt
- nomad
rgh0 wrote:dlbutler wrote:I've recently built a close ratio gearbox . . .
I presume you fitted straight cut gears from Quaiffe? I was not aware that new helical cut close ratio gears to the original design are available?
Yes, Quaiffe straight cut gears via r.d.enterprises. The helical cut gears listed on e-Bay are something I have not seen before. Putting the new gearbox (along with a lot of P.M.) into my Elan is a Winter project. Once back on the road I'll post the results (noise, etc.).
1969 Elan S4
1700 cc, Dave Bean #112 cams.
Union Jack Exotics
Union Jack Exotics
dlbutler - Second Gear
