Anyone recognize this part?
I recently bought some used Elan parts and two of these adapter plates were in the lot.
Does anyone recognize them? The three threaded holes with the bolts in them appear to be the same pattern as an Elan rear stub axle and the other four holes are drilled in a rectangular pattern with one pair on 2 in. centers and the other pair on 2-3/8 in. centers. From what I can tell they are for adapting universal joint sliding drive axle shafts onto a standard triple eared stub axle and/or a standard differential output shaft. Please let me know if this is correct.
Dan
Dan
'66 Elan S2
'05 Lotus Elise
'96 Ferrari F355 GTS
'05 Lotus Elise
- tesprit
Thanks guys. Seeing as these adapter plates are for universal joint half shafts and my Elan is already fitted with CV joint shafts I will not need them, so I will post them in the Parts for Sale section.
'66 Elan S2
'05 Lotus Elise
'05 Lotus Elise
- tesprit
Could they be hub pullers?
Exactly my first impression. The Europa's full of French bits, so why shouldn't your Elan be?
- denicholls2
They look like the adapters that Lotus used to fit Lotus Cortina steel rims to the 6 lug rear hubs from Lotus 22-23 rear hubs on Lotus 31-51 & 61s. Early Formula Fords had to use steel wheels.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Elan45 wrote:They look like the adapters that Lotus used to fit Lotus Cortina steel rims to the 6 lug rear hubs from Lotus 22-23 rear hubs on Lotus 31-51 & 61s. Early Formula Fords had to use steel wheels.
Now that's a possibility I dont think many would have thought off !
