5 Speed gear lever problem.
PostPost by: dougal9887 » Sun Mar 08, 2015 9:14 pm
20150308_164009.jpg and
5 Speed gear lever bush disintegrated.
Anyone got any bright ideas for replacing this cup shaped bush that is now falling apart?
All I can think of is trying to find a toy ball of the same diameter and cutting to size
Bit of a long shot tho'.
Dougal.
dougal9887
PostPost by: rgh0 » Sun Mar 08, 2015 9:30 pm
The gear lever assembly must be off something standard of the period, I have never research what car but someone may know. There should be also levers available from the Elites and Eclats that used this box also from the people who dismantle these cars
PostPost by: vernon.taylor » Mon Mar 09, 2015 11:00 am
Salut
Yes, Escort/Ford(Type 9?) or something like that. They come up on eBay quite often and the complete lever is available from PM and other classic Ford vendors. Don't know if spare parts are available.
Vernon
vernon.taylor
PostPost by: Spyder fan » Mon Mar 09, 2015 2:27 pm
One listed here a 5 speed Elite gearbox @ ?15 + postage [url] http://www.lotusbits.com/elite_chassis.html
[/url]
Here's a picture of the item lifted from S J Sportscars site (new for ?89.50 + VAT and postage)
elite gear lever.jpg and
Kindest regards
Alan Thomas
Spyder fan
PostPost by: john.p.clegg » Mon Mar 09, 2015 3:53 pm
Dougal
Can you post a larger piccy,one showing the full gearlever,I may have a solution..
John :wink:
PostPost by: elansprint » Mon Mar 09, 2015 5:26 pm
We're these not cortina mk3 ?
Ian
elansprint
PostPost by: dougal9887 » Mon Mar 09, 2015 9:31 pm
Thanks for all the replies.
John, I'll post a pic tomorrow.
Dougal.
dougal9887
PostPost by: dougal9887 » Tue Mar 10, 2015 3:50 pm
John,
Here's a picture of the complete gear lever.
20150310_154602.jpg and
5 speed gear lever.
Dougal.
dougal9887
PostPost by: john.p.clegg » Tue Mar 10, 2015 3:58 pm
OK as I thought .you are going to have a right job pulling it apart,unless you've already tried and the pressed-on bush is moving?
Mine has been " Bastardised" and is easy to dissemble
If you can get the rubber bush off I can send you the cup washer you need.
John :wink:
PostPost by: dougal9887 » Tue Mar 10, 2015 7:32 pm
Thanks John, I'll have a look at dis-assembly tomorrow.
Dougal.
dougal9887
PostPost by: dougal9887 » Wed Mar 11, 2015 7:38 pm
John,
Having had a good look at the gear lever assembly, I see what you mean.
The anti vibration joint looks a bit like a metalastic bush.
I could burn it out and on reassembly bond it back in with Flexane moulding rubber, but at ?50 plus for the kit, seems uneconomical.
I've ordered the suggested Elite lever from Lotus bits, very helpful people, and thank you Spyderfan, which should do the trick.
Thanks John for your offer and assistance.
I'll post again and report when the lever arrives!
Dougal
dougal9887
PostPost by: Grizzly » Fri Mar 13, 2015 1:21 pm
Have you seen this http://www.ebay.co.uk/itm/Lotus-Elan-2- ... 20f8351cfa
Just seen it and thought i'd point it out.
PostPost by: john.p.clegg » Fri Mar 13, 2015 1:34 pm
Seems to have the broken part missing?
John :wink:
PostPost by: Grizzly » Fri Mar 13, 2015 1:40 pm
Ahh ok.
Might be worth asking him about though as i'm fairly sure this is the same guy who sold a stripped 5 speed Box not so long ago.
PostPost by: dougal9887 » Fri Mar 13, 2015 7:38 pm
Lever arrived yesterday from Lotus bits. The chrome has a few marks and the top of the rubber boot has a small tear, fortunately horizontal so some super glue should fix it.
Now I'll see how the old one comes apart and if it can be done without destruction I may combine the best of both.
I'll report back.
Dougal.
dougal9887
Next
