Rear suspension Droop limiting devices.
This is what I used when I had spax rear shocks. I found I did not need it when I fitted TTR Koni's The cable connects at the top end with a tab welded to the front bottom of the rear strut tower. The cable took little load as the spring load and weight combined at full droop was only a maybe 20 Kg
Got to love all the engineering in those photo's Steve. I didn't know where to look first.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Norman,
I shortened the piston rod of the strut. You have to be careful though, as having shortened the rod, that rod can then drop into the damper body, probably damaging the seal.
Happy New Year.
Richard Hawkins
Happy New Year.
Richard Hawkins
- RichardHawkins
RichardHawkins wrote:Norman,
Happy New Year.
Richard Hawkins
If I understand you correctly, you use the rod hitting the top of the inside of the damper casing as your droop limiter?
- stevebroad
Steve,
Yes that is correct. If I understand correctly it is the rod hitting the inside of the top of the damper that limits the droop of the original design using rotaflex joints. By shortening the rod at the top end I am actually removing motion from the bottom of the suspension travel. I did this once before for a friend who was using universal joint drive shafts. He wanted 2" removed. I presume he was happy, as he has never mentioned it since.
Richard Hawkins
Richard Hawkins
- RichardHawkins
RichardHawkins wrote:Steve,
Richard Hawkins
Can you describe the procedure for shortening the damper shafts?
My solution is very Heath Robinson but has worked well on my car for years and many miles. Sorry no pics to hand but it is very simple.
I loop a length of 1" wide nylon webbing (luggage strap in fact) over the top of the suspension tower and then clamp each end to the suspension upright with a pair of good quality hose clips. It is easy then to adjust to the maximum safe droop, simply jack up the rear of the car under the upright, put a support under the body (with proper load spreading), then lower the jack to get appropriate maximum droop, checking for free rotation of the CV joints as you go, then jack up a little to allow for take up in the webbing, pull the strap tight both sides and tighten the hose clamps. Finally lower the jack and check free rotation of the shaft and you are all done. The advertised max load of the webbing luggage straps I use is 225k, so a looped strap gives plenty of strength for the load imposed by the drooping suspension bearing in mind that the dampers prevent shock loading.
Vernon
Vernon
Elan S2 26/5614
Alfa Romeo Alfetta Berlina 1974
Westfield 7SE
Westfield 7SE
- quaybook
[/quote]Oh dear, how much weight did you loose/save by making all these chassis holes ?
Sorry, I mean the chassis of course, and not you
Peter[/quote]
1.82kg
Peter[/quote]
1.82kg
- stevebroad
quaybook wrote:My solution is very Heath Robinson but has worked well on my car for years and many miles. Sorry no pics to hand but it is very simple.
I loop a length of 1" wide nylon webbing (luggage strap in fact) over the top of the suspension tower and then clamp each end to the suspension upright with a pair of good quality hose clips Vernon
Much the same here although fitted as a temporary measure I may refine or alter when I get the time.
Users browsing this forum: wdb and 11 guests
