Looking for a Diff Alloy Casing
Hi All,
Just got mine off to discover a broken mounting. Before I weld it back and hope for the best, anybody got a old one laying around you would part with? Thanks.
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
Is it possible to tig weld the mounting bolt section? Would this weaken the casing?
CG901 - Second Gear
If you have managed to break one, you should probably anyway install one of the strengthening bars fitted to the later models.
It's a steel beam that fits across the top using the same mounting holes.
I've seen pictures of Diff cases that have been welded at the top, so I think it is possible.
Bill, good suggestions. I did get that stiffening brace and plan to install it. Only a guess, but I think the diff mounting broke off when a donut let loose and did a lot of damage on the chassis cross member.
CG901 - Second Gear
One of mine was welded up about 15 years ago and still going strong, see this thread:
lotus-gearbox-f37/elan-diffs-t14600.html#p69255
Users browsing this forum: CG901 and 8 guests
