Gearbox ratios
Musing on Elanconvert's topic about diff ratios, can anyone suggest a good method of checking gearbox ratios?
Long ago I exchanged my original gearbox for a refurbished one at an 'ordinary' Ford shop, not a Lotus specialist and on thinking about it I have no idea if it is the proper close ratio box.
It 'felt' the same and I have done many many miles since, but it would be nice to know for sure.
But that is not going to tell him what box he has, all the 4 speed boxes are 1:1 top gear.
Needs to be done in 1st gear, I am assuming you know the diff ratio, follow the procedure I wrote in the diff thread but in 1st gear, divide the final figure by the diff ratio and you will know what 1st gear ratio you have and ergo what gearbox.
- Chancer
Chancer wrote:But that is not going to tell him what box he has, all the 4 speed boxes are 1:1 top gear.
Ah, no, Ron is right. Once you know one of the ratios i.e. the 1:1 of top gear You can calculate the other gear ratios by observing the speedo & rev counter.
E.g. drive at 2500 RPM in each gear and see what speed it is doing.
Even easier, drive at constant speed and note RPM.
billwill wrote:Chancer wrote:But that is not going to tell him what box he has, all the 4 speed boxes are 1:1 top gear.
RogerFrench - Fourth Gear
I understand where you/he were coming from now.
Even easier, - thrash the nuts off it in 1st gear and see how fast it goes
Joking apart even with high numeric diff ratios its easy to tell a 2.54 or a 2.9 first gear, and a 3.3 just feels darn stupid.
- Chancer
Quite right. All you need to know is first gear ratio; that'll tell you what box you have. As mentioned in the other thread, pull the plugs, mark a rear tire at 6:00 and mark the crank pulley somewhere. Push the car for one rev of the tire. Check the crank pulley and knowing it'll be about three revolutions, see where the mark ends up; either before three revs and exactly where, or after three.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Wish I had been able to explain it concisely, however it wont be 3 or so turns of the engine for one turn of the driven wheels but 3 or so times 3 or so turns, the final drive ratio multiplied by the first gear ratio.
Best way though, not relying on speedo's, rev counters, GPS's etc.
- Chancer
Some Numbers for you,
Semi- Close------------------------Close
Top 1:1------------------------------------1:1
3rd 1.396--------------------------------1.230
2nd 2.009--------------------------------1.636
1st 2.972---------------------------------2.510
If you have a semi-close gearbox your revs will double if you change down from top into 2nd gear for the same road speed. Yes I know don?t do at high speed.
As per my first post Rev counter & Speedo absolute accuracy not involved, if you really want to worry then the Rev counter linearity is a source of error. Diff ratio and tyre size are constants.
Ron.
Ron.
- Craven
Thanks for putting all the ratios here, saves me from going to look them up.
I know that my diff is 3.54 as I had it rebuilt to that.
I did the actual 'fitting' myself. Took the old one out & took it to the shop & then fitted the newer one into the car myself.
