Lotus 5-speed nut and bolt sizes
Salut
I'm still slowly collecting the bits and pieces I'll need for a five-speed swap. I can't get imperial nuts and bolts locally so it would be good if I could get absolutely everything together before starting. So if anyone could help with the nut/bolt sizes for the following, that would be a great help:
- bellhousing to 5-speed gearbox bolt set (not essential but might as well change them)
- 5-speed gearbox bracket to chassis nuts/bolts
- clutch cover to flywheel bolts (same as 4-speed ?)
Merci et @+
Vernon
Merci et @+
Vernon
vernon.taylor - Fourth Gear
Vernon
If you can wait a while I'll be lifting my engine and taking the box off in the next couple of weeks I'll draw up a list for you......
Meanwhile
The bellhousing/gearbox bolts should be the same as the four speed,ditto the mounting bracket/chassis and the pressure plate/flywheel...
P.S. If you need a spare pressure plate/flywheel bolt there's on on Fleabay as we speak...and with NO RESERVE...
http://www.ebay.co.uk/itm/390716743318? ... 1555.l2649
No Association etc.etc.
Meanwhile
Salut John
Thanks, that would be very helpful - especially if you can get the bolt sizes for both ends of the bell-housing.
The pressure plate/flywheel bolt is in my watch list. I'll be sniping, as I imagine many will, and I'm fretting over how much I should put as my max snipe - be silly to pay over the odds.
Vernon
Vernon
Very good.. I nearly flipped when I saw it... A full set! Waw!
Alex B ...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Vernon
Missed it in your post but do you still want the bellhousing to gearbox bolt sizes?
anything else?
anything else?
Salut
Alan: thanks, good tip.
John: thanks, to have everything in the same place you sent me this (thank you):
1. Can you confirm the 5-speed speedo cable (minimum) length, please ?
2. I hope my galvanised chassis has 5-speed gearbox mounting plate holes already - are they usually tapped ? Bolt size ?
3. Any photos and tips of your 5-speed re-install would be appreciated and make a nice complete thread.
Merci
Vernon
Merci
Vernon
Vernon
Just had a look,the speedo cable,mine is already installed,looks like a good fit at 50" (1.3m)
My chassis looks like a galvanized lotus jobbie and the extra holes are there 5/16" UNF and the bolts (4) approx 9/16" same as the 4-speeder.
When I refitted my gearbox I struggled,even though I have a large access hole,juggling the heavy gearbox over the "step" in the opening while trying to align the splines,when I first fitted it , it were the bolts that I screwed in in-situ (about 1/8 turn at a time)...is any job on a Lotus easy/quick/simple?...but worth it.
Salut John
So are you saying that bolting the gearbox to the engine first is possible easier.
Vernon
Vernon
Vernon
No,it is difficult in the spine of the chassis connecting the splines or the bolts,whichever way you want to do it I think it would be easier to fit the gearbox on its own then the engine,if the gearbox is connected to the prop-shaft (the difficult bit) then before fixing the mounting plate the gearbox will pull forward a little,making it easier to fit the bell-housing bolts and then when the two are mated together fit the mounting plate bolts.
