Speedo right angle drive
I had to pull the engine/gearbox due to oil leaking from the bell housing, so I have a couple of things to address.
First issue is what sealer is recommended to put on the one through bolt gearbox to bell housing?
I also find that I don't have an O ring on the speedo drive but my parts book has a poor copy of the page F10 which shows the O ring part#FA38. Can anyone send me a photocopy of that page which is readable?
What I can see it looks like the O ring goes between the gearbox & the alloy spacer piece but the O ring I have been sent seems to big. Can anyone explain where it goes?
Keith Marshall
- saildrive2001
The O ring sits in a groove in the aluminium gear housing. Found this image on the net...not the Elan (Ford) box I don't think but the principle is the same
S4 DHC
S4 DHC
- oldelanman
That would be helpful. There are two aluminium parts which threw me 39 & 41. I didn't realize at first that 39 was a separate part. I guess that there are no gaskets or O rings outboard of 39.
Keith Marshall
- saildrive2001
If you can download the scan from the '66 parts list (S1, 2 and Coupe) and enlarge it, I think the part you're looking for is listed as item 21 - PN E316-NE-1 Gasket (speedometer cable).
- Attachments
- SCN_0004.pdf
- (275.87 KiB) Downloaded 389 times
Mazzini - Coveted Fifth Gear
