Differential Torque Rods
Dear All,
I am in the process of rebuilding the rear suspension and now I have access to the differential I thought I would replace the bushes on the torque rods (?) that connect the diff' to the chassis. What I can't work out is whether the attachment is via a straight forward bolt or is the bolt welded to the chassis (mine won't budge and I don't what to push it until I knwo I can replace it with a normal bolt)
1972 +2S130
tdafforn - Coveted Fifth Gear
Tim,
I have seen both loose and fixed bolts, although I believe they originally were fixed by just a small tack weld. The tack weld breaks and the bolt becomes loose.
Check the frame around the bolt hole as it is prone to cracking around the attachment point.
